Date/Time: Tue, 16 Sep 2025 18:52:36 +0000
[Programming Help] - color candlesticks, need help
View Count: 1692
[2018-11-22 00:12:16] |
What gets set to ignore? We assume you are referring to a Subgraph. But which one. And tell us the specific study you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-30 18:28:23] |
Sawtooth - Posts: 4263 |
The CandleStick Patterns Finder study's SG2-SG6 will revert to the Ignore draw style because the text for all patterns is controlled from SG1. (Yes, this is confusing). To color a price bar when Pattern 2 and Pattern 3 are found, use two instances of the Color Bar Based On Alert Condition study, one for each pattern. You don't need to set the Based On to the CandleStick Patterns Finder study. Use one of these formulas in each instance, respectively: =ID1.SG2>0 =ID1.SG3>0 where the CandleStick Patterns Finder study is ID1. Edit as needed. |
