Date/Time: Fri, 13 Nov 2026 17:05:34 +0000
Volume at Price Threshold Alert V2 - Compare bid/ask volume with
View Count: 1339
| [2018-11-16 19:13:38] |
| User860287 - Posts: 2 |
Good morning, I want to compare the Bid and Ask volume at individual price levels, and have extension lines drawn for each true comparison. If I understand it correctly, the Volume at Price Threshold Alert V2 only takes into account >=. However, in my case, a condition needs to be true when Bid volume "equals" (==) Ask volume at an individual price level. Is this possible using the mentioned study? Also, is it further possible to make volume comparisons between the bid and ask at individual price levels with <= and include an absolute numerator as well? For example, the condition is true when: bid volume - ask volume <= |x| If not, is there a price level study that support these requirements? Thank you Date Time Of Last Edit: 2018-11-16 19:17:32
| [2018-11-16 20:59:12] |
You are able to modify the source code of that study to meet your requirements. Refer to: How to Build an Advanced Custom Study from Source Code This is the best way to accomplish what you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-16 21:00:03
