Date/Time: Fri, 13 Nov 2026 17:19:42 +0000
Numbers bars ==> .CPP
View Count: 1183
| [2018-11-12 07:45:35] |
| stephane1 - Posts: 112 |
Hello, Where is the .CPP for the 'Numbers Bars" study, I don't find it in ACS folder? best SR |
| [2018-11-12 08:15:30] |
This is not available. Refer to: How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available (Source Code for Some Built in Studies Not Available) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
