Date/Time: Fri, 13 Nov 2026 17:19:34 +0000
Building Custom Studies Causes Bug
View Count: 1047
| [2018-11-09 14:17:57] |
| User41727 - Posts: 124 |
If you release the DLLs, recompile an existing one and then re-enable loading, custom studies in the studies menu for charts only show (unknown name) until the next restart of SC.
| [2018-11-09 20:51:39] |
We are checking into this.
| [2018-11-12 01:29:56] |
This will be resolved in the next release. But one thing we realize is that when the study DLLs are denied to be loaded and you add a study to the chart or open a Chartbook, those studies will not be in a correct state until the study is removed from the chart and added again or the Chartbook is reopened.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-12 01:30:22
