Date/Time: Fri, 13 Nov 2026 17:19:30 +0000
chart scrolling
View Count: 1627
| [2018-11-09 14:13:31] |
| User884550 - Posts: 149 |
how to keep chart on same price when scrolling back? mine is jumping with prices on the screen, but i want to scroll back in time at same prices |
| [2018-11-09 18:24:24] |
By default the scale is updated to show the chart bars completely. To do what you want you need to refer to the Using Fixed Values for Top and Bottom of Scale Range section here: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
