Date/Time: Fri, 13 Nov 2026 17:19:33 +0000
I activated the real time data
View Count: 1245
| [2018-11-07 15:38:09] |
| User145885 - Posts: 15 |
Thank you for your help.I am now receiving data but a)limited history data b) the following message log do not stop Software version: 1820 64-bit | 2018-11-07 09:21:59 Usage end date: 2018-12-02 | 2018-11-07 09:21:59 Enabled for: Advanced Features. | 2018-11-07 09:21:59 Enabled for: Advanced Features 2. | 2018-11-07 09:21:59 Enabled for: Sierra Chart Historical Data Service. | 2018-11-07 09:21:59 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-11-07 09:21:59 Enabled for: INDEXES_DATA_BARCHART | 2018-11-07 09:21:59 Enabled for: CME (Trading Account Required) | 2018-11-07 09:21:59 Enabled for: CBOT (Trading Account Required) | 2018-11-07 09:21:59 Enabled for: COMEX (Trading Account Required) | 2018-11-07 09:21:59 Enabled for: NYMEX (Trading Account Required) | 2018-11-07 09:21:59 Received 1 data feed usernames. | 2018-11-07 09:21:59 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-11-07 09:21:59 Current selected Data/Trading service: TD Ameritrade | 2018-11-07 09:21:59 Chart Update Interval: 500 | 2018-11-07 09:21:59 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-11-07 09:21:59 2018-11-07 09:21:59 Local computer time | 2018-11-07 09:21:59 2018-11-07 14:21:59 Local computer time in UTC | 2018-11-07 09:21:59 2018-11-07 09:21:59 Local computer time in SC Time Zone | 2018-11-07 09:21:59 2018-11-07 14:16:43 Server time in UTC | 2018-11-07 09:21:59 Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-11-07 09:21:59 Program path: C:\SierraChart\ | 2018-11-07 09:21:59 Data Files path: C:\SierraChart\Data\ | 2018-11-07 09:21:59 OS Version Number: 6.1 | 2018-11-07 09:21:59 Locale Setting: C | 2018-11-07 09:21:59 TD Ameritrade | Connecting. | 2018-11-07 09:22:14 TD Ameritrade | Logging in. (Step 1 of 3) | 2018-11-07 09:22:14 HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2018-11-07 09:22:14 HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2018-11-07 09:22:14 TD Ameritrade | Authorized for streamer data. Account: 86*** | 2018-11-07 09:22:14 TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2018-11-07 09:22:14 TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2018-11-07 09:22:14 TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2018-11-07 09:22:14 TD Ameritrade | Connected to data and trading server. | 2018-11-07 09:22:14 Mapping YMZ18 to YMZ18. Service code: cbot | 2018-11-07 09:22:14 SC Data - All Services | Starting real-time market data updates for: YMZ18. ID: 1 | 2018-11-07 09:22:14 SC Data - All Services | Using username 0 | 2018-11-07 09:22:14 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-11-07 09:22:14 SC Data - All Services | Requesting security definition data for: YMZ18. ID: 1 | 2018-11-07 09:22:14 Intraday data recording state for symbol YMZ18 is set to download 'Pending'. | 2018-11-07 09:22:14 DTC Client socket (2) | Creating socket. | 2018-11-07 09:22:14 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2018-11-07 09:22:14 Delaying start of download for YMZ18 | 2018-11-07 09:22:14 SC Data - All Services | Connected to server. | 2018-11-07 09:22:14 SC Data - All Services | Starting socket receive thread. | 2018-11-07 09:22:14 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-11-07 09:22:14 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-11-07 09:22:14 SC Data - All Services | Sending logon request message. | 2018-11-07 09:22:14 SC Data - All Services | Received logon response. | 2018-11-07 09:22:14 SC Data - All Services | Server Name: SC Realtime Server. | 2018-11-07 09:22:14 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-11-07 09:22:14 SC Data - All Services | Successfully connected. | 2018-11-07 09:22:14 SC Data - All Services | Trading is not supported. | 2018-11-07 09:22:14 SC Data - All Services | Restarting real-time data updates for symbol: YMZ18 -> YMZ18 | 2018-11-07 09:22:14 SC Data - All Services | Received security definition for symbol YMZ18 | 2018-11-07 09:22:14 TD Ameritrade | Streamer request #75 initiated. | 2018-11-07 09:22:15 HTTPS ameritrade02.streamer.com:443 (3) | Creating socket. Using TLS 1.0. | 2018-11-07 09:22:15 HTTPS ameritrade02.streamer.com:443 (3) | Connecting to IP: 198.200.171.138. | 2018-11-07 09:22:15 HTTPS ameritrade02.streamer.com:443 (3) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-11-07 09:22:15 HTTPS ameritrade02.streamer.com:443 (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-07 09:22:15 * HTTPS ameritrade02.streamer.com:443 (3) | Signaling to core to close socket | 2018-11-07 09:22:15 TD Ameritrade | Lost the connection with the streamer. Request ID: 75. Will re-request data. | 2018-11-07 09:22:15 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-11-07 09:22:15 HTTPS ameritrade02.streamer.com:443 (3) | Received socket Close event. | 2018-11-07 09:22:15 HTTPS ameritrade02.streamer.com:443 (3) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:15 TD Ameritrade | Starting real-time market data updates for: DATE TIME. ID: 2 | 2018-11-07 09:22:16 TD Ameritrade | Requesting security definition data for: DATE TIME. ID: 2 | 2018-11-07 09:22:16 TD Ameritrade | Streamer request #76 initiated. | 2018-11-07 09:22:18 HTTPS ameritrade02.streamer.com:443 (4) | Creating socket. Using TLS 1.0. | 2018-11-07 09:22:18 HTTPS ameritrade02.streamer.com:443 (4) | Connecting to IP: 198.200.171.138. | 2018-11-07 09:22:18 HTTPS ameritrade02.streamer.com:443 (4) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-11-07 09:22:18 HTTPS ameritrade02.streamer.com:443 (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-07 09:22:18 * HTTPS ameritrade02.streamer.com:443 (4) | Signaling to core to close socket | 2018-11-07 09:22:18 HTTPS ameritrade02.streamer.com:443 (4) | Received socket Close event. | 2018-11-07 09:22:18 TD Ameritrade | Lost the connection with the streamer. Request ID: 76. Will re-request data. | 2018-11-07 09:22:18 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-11-07 09:22:18 HTTPS ameritrade02.streamer.com:443 (4) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:18 HD Request # 4 | Downloading Intraday chart data for YMZ18 to the file YMZ18.scid. Service: cbot | 2018-11-07 09:22:20 HD Request # 4 | Download start date-time: 2018-11-07 09:19:35.000 | 2018-11-07 09:22:20 HD Request # 4 | Using server: ds7.sierracharts.com port 10149 | 2018-11-07 09:22:20 Socket (5) | Creating socket. | 2018-11-07 09:22:20 Socket (5) | Connecting to IP: 8.18.161.133. | 2018-11-07 09:22:20 HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-11-07 09:22:20 HD Request # 4 | Sending historical data logon request message. | 2018-11-07 09:22:20 TD Ameritrade | Streamer request #77 initiated. | 2018-11-07 09:22:20 HTTPS ameritrade02.streamer.com:443 (6) | Creating socket. Using TLS 1.0. | 2018-11-07 09:22:20 HTTPS ameritrade02.streamer.com:443 (6) | Connecting to IP: 198.200.171.138. | 2018-11-07 09:22:20 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-11-07 09:19:35. Record interval: 0. Symbol: YMZ18 | 2018-11-07 09:22:20 HTTPS ameritrade02.streamer.com:443 (6) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-11-07 09:22:20 HTTPS ameritrade02.streamer.com:443 (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-07 09:22:20 * HTTPS ameritrade02.streamer.com:443 (6) | Received socket Close event. | 2018-11-07 09:22:20 HD Request # 4 | Decompressing data. | 2018-11-07 09:22:20 HD Request # 4 | Receiving Intraday data for YMZ18 starting at 2018-11-07 09:19:35 | 2018-11-07 09:22:20 HD Request # 4 | Timestamp of first Intraday data file record written: 2018-11-07 09:19:40 | 2018-11-07 09:22:20 Socket (5) | Signaling to core to close socket | 2018-11-07 09:22:20 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:20 HTTPS ameritrade02.streamer.com:443 (6) | Signaling to core to close socket | 2018-11-07 09:22:20 TD Ameritrade | Lost the connection with the streamer. Request ID: 77. Will re-request data. | 2018-11-07 09:22:20 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-11-07 09:22:20 HTTPS ameritrade02.streamer.com:443 (6) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:20 Historical data download thread signaled to stop. | 2018-11-07 09:22:20 HD Request # 4 | Received 223 records from 2018-11-07 09:19:35 to 2018-11-07 09:22:18 (2.7 minutes) and wrote 222 records for YMZ18 | 2018-11-07 09:22:20 Added 7 Time and Sales records to Intraday data file for YMZ18 after download. | 2018-11-07 09:22:20 HD Request # 4 | Completion time: 1s | 2018-11-07 09:22:20 HD Request # 4 | Intraday data download complete for YMZ18. Unique request ID: 3 | 2018-11-07 09:22:20 Removed historical data download ID 3 | 2018-11-07 09:22:20 Real-time Intraday chart data file updates started for YMZ18 | 2018-11-07 09:22:20 Intraday chart data file opened for YMZ18 | 2018-11-07 09:22:20 Socket (5) | Socket gracefully closed by remote side. | 2018-11-07 09:22:20 Socket (5) | Closed. | 2018-11-07 09:22:20 TD Ameritrade | Streamer request #78 initiated. | 2018-11-07 09:22:22 HTTPS ameritrade02.streamer.com:443 (5) | Creating socket. Using TLS 1.0. | 2018-11-07 09:22:22 HTTPS ameritrade02.streamer.com:443 (5) | Connecting to IP: 198.200.171.138. | 2018-11-07 09:22:22 HTTPS ameritrade02.streamer.com:443 (5) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-11-07 09:22:22 HTTPS ameritrade02.streamer.com:443 (5) | Signaling to core to close socket | 2018-11-07 09:22:22 TD Ameritrade | Lost the connection with the streamer. Request ID: 78. Will re-request data. | 2018-11-07 09:22:22 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-11-07 09:22:22 HTTPS ameritrade02.streamer.com:443 (5) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:22 HTTPS ameritrade02.streamer.com:443 (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-07 09:22:22 * HTTPS ameritrade02.streamer.com:443 (5) | Received socket Close event. | 2018-11-07 09:22:22 HTTPS ameritrade02.streamer.com:443 (5) | Still waiting for graceful close or receive error. | 2018-11-07 09:22:22 Opened cached Intraday file: C:\SierraChart\Data\YMZ18.scid | 2018-11-07 09:22:23 TD Ameritrade | Streamer request #79 initiated. | 2018-11-07 09:22:24 HTTPS ameritrade02.streamer.com:443 (7) | Creating socket. Using TLS 1.0. | 2018-11-07 09:22:24 HTTPS ameritrade02.streamer.com:443 (7) | Connecting to IP: 198.200.171.138. | 2018-11-07 09:22:24 HTTPS ameritrade02.streamer.com:443 (7) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-11-07 09:22:24 HTTPS ameritrade02.streamer.com:443 (7) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-07 09:22:24 * HTTPS ameritrade02.streamer.com:443 (7) | Signaling to core to close socket | 2018-11-07 09:22:24 TD Ameritrade | Lost the connection with the streamer. Request ID: 79. Will re-request data. | 2018-11-07 09:22:24 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-11-07 09:22:24 HTTPS ameritrade02.streamer.com:443 (7) | Received socket Close event. | 2018-11-07 09:22:24 HTTPS ameritrade02.streamer.com:443 (7) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:24 TD Ameritrade | Streamer request #80 initiated. | 2018-11-07 09:22:26 HTTPS ameritrade02.streamer.com:443 (8) | Creating socket. Using TLS 1.0. | 2018-11-07 09:22:26 HTTPS ameritrade02.streamer.com:443 (8) | Connecting to IP: 198.200.171.138. | 2018-11-07 09:22:26 HTTPS ameritrade02.streamer.com:443 (8) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-11-07 09:22:27 HTTPS ameritrade02.streamer.com:443 (8) | Signaling to core to close socket | 2018-11-07 09:22:27 TD Ameritrade | Lost the connection with the streamer. Request ID: 80. Will re-request data. | 2018-11-07 09:22:27 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-11-07 09:22:27 HTTPS ameritrade02.streamer.com:443 (8) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:27 HTTPS ameritrade02.streamer.com:443 (8) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-07 09:22:27 * HTTPS ameritrade02.streamer.com:443 (8) | Received socket Close event. | 2018-11-07 09:22:27 HTTPS ameritrade02.streamer.com:443 (8) | Still waiting for graceful close or receive error. | 2018-11-07 09:22:27 TD Ameritrade | Streamer request #81 initiated. | 2018-11-07 09:22:29 HTTPS ameritrade02.streamer.com:443 (9) | Creating socket. Using TLS 1.0. | 2018-11-07 09:22:29 HTTPS ameritrade02.streamer.com:443 (9) | Connecting to IP: 198.200.171.138. | 2018-11-07 09:22:29 HTTPS ameritrade02.streamer.com:443 (9) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-11-07 09:22:29 HTTPS ameritrade02.streamer.com:443 (9) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-07 09:22:29 * HTTPS ameritrade02.streamer.com:443 (9) | Received socket Close event. | 2018-11-07 09:22:29 HTTPS ameritrade02.streamer.com:443 (9) | Signaling to core to close socket | 2018-11-07 09:22:29 HTTPS ameritrade02.streamer.com:443 (9) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:29 TD Ameritrade | Lost the connection with the streamer. Request ID: 81. Will re-request data. | 2018-11-07 09:22:29 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-11-07 09:22:29 TD Ameritrade | Streamer request #82 initiated. | 2018-11-07 09:22:31 HTTPS ameritrade02.streamer.com:443 (10) | Creating socket. Using TLS 1.0. | 2018-11-07 09:22:31 HTTPS ameritrade02.streamer.com:443 (10) | Connecting to IP: 198.200.171.138. | 2018-11-07 09:22:31 HTTPS ameritrade02.streamer.com:443 (10) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-11-07 09:22:31 HTTPS ameritrade02.streamer.com:443 (10) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-07 09:22:31 * HTTPS ameritrade02.streamer.com:443 (10) | Received socket Close event. | 2018-11-07 09:22:31 HTTPS ameritrade02.streamer.com:443 (10) | Signaling to core to close socket | 2018-11-07 09:22:31 HTTPS ameritrade02.streamer.com:443 (10) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:31 TD Ameritrade | Lost the connection with the streamer. Request ID: 82. Will re-request data. | 2018-11-07 09:22:31 If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-11-07 09:22:31 File >> Disconnect selected. | 2018-11-07 09:22:32 HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2018-11-07 09:22:32 HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:32 DTC Client socket (2) | 364 bytes remaining in receive buffer when socket closed. | 2018-11-07 09:22:32 DTC Client socket (2) | Signaling to core to close socket | 2018-11-07 09:22:32 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-07 09:22:32 SC Data - All Services | Disconnected from the server. | 2018-11-07 09:22:32 TD Ameritrade | Disconnected. | 2018-11-07 09:22:32 Disconnected from TD Ameritrade. | 2018-11-07 09:22:32 HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2018-11-07 09:22:32 HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2018-11-07 09:22:32 DTC Client socket (2) | Socket gracefully closed by remote side. | 2018-11-07 09:22:32 DTC Client socket (2) | Closed. | 2018-11-07 09:22:32 |
| [2018-11-07 18:07:40] |
Make sure you follow step number 6 here when using TD Ameritrade: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions We recommend that you set Global Settings >> Data/Trade Service Settings >> Service to SC Data-All Services And follow the instructions here to connect once a month to your trading account: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ConnectingOnlyOnceAMonthToTradingAccount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
