Date/Time: Fri, 13 Nov 2026 17:29:46 +0000
File >> New Instance doesn't copy spreadsheets
View Count: 849
| [2018-11-04 20:39:27] |
| ForgivingComputers.com - Posts: 1253 |
Copies OK: *.cht *.dll *.StdyCollct *.twconfig others? Does not copy: *.scss |
| [2018-11-04 23:39:37] |
We will add the copying of spreadsheets as well.
