Date/Time: Fri, 13 Nov 2026 17:29:45 +0000
Ver 1835
View Count: 1018
| [2018-11-04 20:06:09] |
| NRGTrader - Posts: 351 |
Update to version 1835. All my charts that had been using adxcolor study now do NOT have that study.
| [2018-11-04 21:19:04] |
This is a user contributed study and we tested it and do not see any problem with this. What do you mean by "do not have that study"? You can find it in the User Contributed Studies: How to Use an Advanced Custom Study or a Study Collection: How to Use an Advanced Custom Study Provided To You Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-04 21:19:22
| [2018-11-04 21:41:11] |
>What do you mean by "do not have that study"? The charts that access that study show a blank area for where that study was plotted on on every version. The version I had installed prior to upgrading to Ver 1835 was 1834. It seems like maybe the name of the study changed. |
| [2018-11-04 21:54:02] |
Actually it appears maybe a 32 bit version of Sierra Chart was installed. I was using 64 bit. I upgraded as usual, download pre-release from within Sierra Chart.
Date Time Of Last Edit: 2018-11-04 21:57:57
Private File Private File |
| [2018-11-04 22:47:46] |
| user8888 - Posts: 159 |
same thing happens to me with another study. error loading UserContributedStudies.dll, windows error code 193: is not a valid win32 App. this error does not appear in the message log, but in the window where you set the studies, to the right side of the contributed study. since that window is small and of fixed size, I don't know how to take a screenshot of it. Date Time Of Last Edit: 2018-11-04 23:05:10
| [2018-11-04 23:24:02] |
Actually it does show in the log. Check the beginning of the message log. The first symbol that loads with that study included in chart generates the error message.
| [2018-11-05 01:49:45] |
We see the reason for the problem. This will be solved with a new release coming out later this evening. For now make sure you are running the 64-bit version of Sierra Chart.
