Date/Time: Wed, 14 Oct 2026 16:16:07 +0000
Auto retracement/projection Study
View Count: 2460
| [2018-10-31 23:06:43] |
| katek - Posts: 28 |
Hi, I was looking for a study that allows retracement/projection with a define start time/end time and couldn't find one. For instance, I would like to make projection based on the previous day range. Is there any study that does this? Thank you |
| [2018-11-01 19:17:52] |
This is not supported with the Auto Retracement/Projection study that Sierra Chart has. It does not support referencing a prior day.
| [2019-06-09 09:44:53] |
| Ackin - Posts: 1865 |
Hi, It's possible download it for free from our CZ/SK forum. contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:25:39
