Date/Time: Tue, 07 May 2024 13:19:36 +0000
Delay in exchange data feed
View Count: 2352
[2018-11-03 02:24:19] |
When you notice the problem again look at Window >> Message Log and see if there any messages in the log which occur at that time. If so copy and paste them here. This is not at a time when the market is busy so we do not see how this is related to the additional market depth levels for the CME markets. There must be some other cause. This sounds like more of a network level issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-05 08:02:13] |
User998143 , we did cancel the data feed for you on Friday. If you want to continue to use it you need to reactivate it here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures You will be billed the remaining amount until the end of the month and there is no refund. We will be working on the issue this coming week, but we are concerned in your case you could still have a potential lagging condition, due to the higher bandwidth requirement for the additional levels of market depth. For now you can use low bandwidth mode. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
