Date/Time: Fri, 13 Nov 2026 17:42:04 +0000
How to get SC to remember my Data Provider selection in Global Settings?
View Count: 880
| [2018-10-20 15:28:08] |
| TraderTen - Posts: 80 |
This is a possible duplicate post, as the first one I sent caused an error message that said: 'ERROR: Invalid Post ID' HERE IS MY QUESTION: Several weeks ago I changed my data provider with AMP from CQG to Rithmic, which has been working fine. Except for one issue: SC will not save the Rithmic selection in Global Settings. Thus I have to manual select it every time I load SC. Furthermore, I then have to go to File to request the Connection be opened. That gets to be pretty old if I am doing it multiple times per day. Any suggestion on how to get SC to remember my Data feed selection? |
| [2018-10-20 21:10:06] |
We need to disable the automatic setting of Data/Trade Service settings for your Sierra Chart account. This is now done.
