Date/Time: Fri, 13 Nov 2026 17:42:03 +0000
[Programming Help] - please increase sc.input[] array input limit from 128
View Count: 1226
| [2018-10-19 10:43:14] |
| User553714 - Posts: 186 |
Hi, If it's not too much trouble can you please increase the number of User Inputs from the current limit of 128 as I am starting to run out of available inputs. Thanks |
| [2018-10-19 20:14:28] |
Yes it is a lot of difficulty. We do not foresee this. We recommend using Text string inputs instead and you can separate multiple input values with a delimiter like a comma.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-19 20:14:40
| [2018-10-20 15:04:17] |
| ertrader - Posts: 700 |
I have the same issue in addition to subgraph limits of 60. Are there code examples you can point us to that shows how to do text string inputs? I've done them but only for selecting 1 value in a list.
Date Time Of Last Edit: 2018-10-20 15:05:19
