Date/Time: Fri, 13 Nov 2026 17:41:55 +0000
SMA and EMA studies displaying incorrectly
View Count: 1065
| [2018-10-18 12:18:37] |
| bodzhar - Posts: 19 |
Hi, I have a 20ema, 100 and 200sma's as studies in my daily chart. As of today they are displaying incorrectly in that chart, around 40% higher than they should be but correctly in the 5 min and 15 sec charts those studies are linked to. I tried deleting and reinstating them but no difference. Any idea how to fix this problem? |
| [2018-10-18 17:42:53] |
Make sure those studies are set to use an Automatic Scale Range: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-10-24 15:21:23] |
They are set to automatic scale range. I should add this issue started after I upgraded to build 1823 a couple of weeks back Date Time Of Last Edit: 2018-10-24 15:26:53
| [2018-10-24 18:15:04] |
We need to understand precisely what the problem is. Provide a screenshot of the chart showing the problem and explain how you come to the conclusion there is a problem. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-24 18:15:27
