Date/Time: Fri, 13 Nov 2026 16:39:30 +0000
Digit Group Separators
View Count: 1301
[2018-10-17 14:40:31]
User465507 - Posts: 74
I can see that charts can show numbers with a separator to make reading it easier, e.g., 12384 becomes 12,384. There are different standards for this, e.g., some countries use spaces, but UK & US and many other countries separate by thousands with a comma.
I can see this is already implemented with shortening in the format of say 10.0k from 10000. Is there any way to get this working in market depth, DOM, times and sales, etc.? It would make reading the numbers much easier and let you see at a glance what's a big order and what's small etc., since 50K might be spatially smaller than 1M.
Any chance of this being added as an option?
Otherwise, great software with huge value for the price, still learning it all. Well done.
[2018-10-17 17:12:30]
Can you provide a screenshot of the market depth window at the time you want to see this so we can have an understanding of the numbers. Here are instructions:
You can open the Market Depth window and position it over a chart and use Edit >> Screen Images >> Upload Chart with Overlays and paste the link here.
Date Time Of Last Edit: 2018-10-17 17:12:54
[2018-10-17 18:08:00]
File attached
Private File
[2018-10-25 12:50:01]
Okay I found a setting in some indicators called "Use Large Number Display Formatting" Is it possible to get this in the market depth Window?
[2018-10-26 18:42:40]
Yes. We will see about this. Probably needs to be an option.
[2018-12-12 22:14:59]
We are going to add "Use Large Number Display Formatting" for the Market Depth window. The option will be in Chart >> Chart Settings.
