Date/Time: Fri, 13 Nov 2026 17:54:00 +0000
Starting account after free trial
View Count: 847
| [2018-10-17 05:43:07] |
| User593222 - Posts: 3 |
Hi, I have been trading a combine with One Up through Rithmic for a month, everything going well. I need to start a paying subscription with Sierra. My platform fees are paid, as with Topstep trader clients. Can I just pay you and everything carries on exactly as in the last month? I don't want a situation where I start a subscription with you and my trading setup is different to the way it has been, with regard to data and feeds. What am I in for 33$ per month. I am not a computer geek, so please in laymans terms, if needed Thanks
| [2018-10-17 05:45:44] |
| [2018-10-17 05:51:40] |
Can I just pay you and everything carries on exactly as in the last month? Yes this is the case. Your account is still active until 2018-10-19 . It will just carry on the same way.Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
