Date/Time: Sat, 10 Oct 2026 12:10:59 +0000
ACSIL error remote compiling GDIExample.cpp
View Count: 2007
[2018-10-15 13:23:01]
wwwingman - Posts: 185
I tried to compile the GDIExample.cpp using the remote compiler. I use the 1820 version, and the errors I get are :
-- Starting remote build of Custom Studies Source files: GDIExample.cpp. 64-bit -- 08:19:55
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
/tmp/ccRvihR8.o:GDIExample.cpp:(.text+0x12): undefined reference to `__imp_CreateSolidBrush'
/tmp/ccRvihR8.o:GDIExample.cpp:(.text+0x1f): undefined reference to `__imp_SelectObject'
/tmp/ccRvihR8.o:GDIExample.cpp:(.text+0x43): undefined reference to `__imp_Rectangle'
/tmp/ccRvihR8.o:GDIExample.cpp:(.text+0x54): undefined reference to `__imp_DeleteObject'
/tmp/ccRvihR8.o:GDIExample.cpp:(.text+0x5f): undefined reference to `__imp_SetTextAlign'
/tmp/ccRvihR8.o:GDIExample.cpp:(.text+0x82): undefined reference to `__imp_TextOutA'
collect2: error: ld returned 1 exit status
-- End of Build -- 08:20:02
-- W
[2018-10-15 18:33:07]
In this case we recommend using the Microsoft Visual C++ compiler which you can also access through the Build Custom Studies window.
