Date/Time: Fri, 13 Nov 2026 17:53:50 +0000
CAMARILLA PIVOT POINTS SG16 AND SG17
View Count: 1696
| [2018-10-10 05:22:31] |
| User63769 - Posts: 39 |
NOT ALL THE SUBGRAPHS OF THE CAMARILLA PIVOT POINTS APPEAR ON THE CHART. R3.5 AND S3.5 (SG16 AND SG17)WOULD BE PARTICULARLY USEFUL. HOW CAN I GET THESE SUBGRAPHS TO APPEAR ON THE CHART?
| [2018-10-10 07:47:32] |
We will see if these can be added based on the formula.
| [2018-10-10 15:37:41] |
| John - SC Support - Posts: 48526 |
We have gone ahead and added these Support and Resistance lines to the Pivot Point calculations for Formula #5. This will be available in the next Pre-Release (1821). You will find the updated documentation for these calculations here: Pivot Points: Formula Type 5 (Camarilla Pivot Points) When available, you can update to the latest Pre-Release following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
