Date/Time: Fri, 13 Nov 2026 18:06:00 +0000
ASCIL Replay functions ?
View Count: 1352
| [2018-10-08 09:57:46] |
| User210074 - Posts: 63 |
Hello. Are there any ACSIL functions to control setting a replay on a single chart? Can I start a REPLAY from a date in ACSIL code? The parameters of use of the REPLAY is here: Replaying Charts But I can not find anything in the site about it when I do a keyword search. Oups, i just find this but no more ! ACSIL Interface Members - Variables and Arrays: sc.ReplayStatus |
| [2018-10-08 10:50:31] |
This is not supported.
| [2018-10-08 11:40:12] |
OK thanks for your answer
