Date/Time: Fri, 13 Nov 2026 18:06:00 +0000
Color Bar Based Alert - Extend to future intersection
View Count: 1111
| [2018-10-07 21:37:35] |
| User132748 - Posts: 159 |
I have a problem with Color Bar based Alert. Option of extending the alert value to future intersection works as it was set to extend to end of chart (see picture). Am I doing something wrong or not understanding how it should work? I need to extend the study value indicated by blue arrow until intersection. |
Private File |
| [2018-10-08 10:25:26] |
This is definitively not going to work as you expect when that study is based on a study which does not consist of the main price graph bars. This is just not supported.
