Date/Time: Fri, 13 Nov 2026 18:05:56 +0000
Spreadsheet automated trading
View Count: 884
| [2018-10-07 07:50:47] |
| stephane1 - Posts: 112 |
Hi How can I show 'orders and positions' on graph when I use 'Spreadsheet automated trading', is it possible ? thank you SR |
| [2018-10-07 09:33:53] |
Specifically what are you looking for? There is a cell on the Sheet used by the Spreadsheet System for Trading study, that does contain the current Trade Position Quantity.
| [2018-10-07 10:41:20] |
I am looking to see on the graph the lines BUY,SELL Market, SL and TP level. best SR |
| [2018-10-07 22:42:07] |
Refer to: Chart Trading and the Chart DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
