Date/Time: Fri, 13 Nov 2026 18:05:56 +0000
Can I Chart a Custom Index from Spreadsheet Data?
View Count: 930
| [2018-10-06 21:36:55] |
| Halco - Posts: 92 |
Can I chart spreadsheet data? I'd like to create an index of about 50 instruments but I don't want 50 charts open at the same time. Instead I'd like to open and then close each chart so the price data is fed to the spreadsheet, combine the data in the spreadsheet and then chart that. Can SC do that? Thanks!
| [2018-10-08 10:34:15] |
Have a look at using this new study: Add Additional Symbol You can then use the Spreadsheet study and do custom calculations using all of the data in the chart and see the result through the Subgraphs of the Spreadsheet Study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
