Date/Time: Fri, 13 Nov 2026 18:06:06 +0000
Load a Specific Date in Chart
View Count: 1129
| [2018-10-06 16:57:55] |
| User94606 - Posts: 327 |
Is there a way to load a specific date (e.g., July 15, 2016) into a chart instead of specifying the total number of days to load?
| [2018-10-06 17:13:00] |
To clarify: I am looking to load ES futures contract for July 14, 2016. Need the symbol/contract name for ES for July 14, 2016
| [2018-10-08 10:32:37] |
You need to use this setting: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo Since you are using Interactive Brokers the symbol will be ES-201609-GLOBEX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
