Date/Time: Fri, 13 Nov 2026 18:06:08 +0000
Pitchfork line colors not working
View Count: 949
| [2018-10-05 21:00:23] |
| User249839 - Posts: 1 |
Hello, since I upgraded to 1815 all the pitchforks on all my charts are now a single color. It is always the last color in the list of lines that you have entered in the options box. All of the colors of the lines in the options box that were set are all still there and correct, but all lines are set to the last color. I have backed up to previous version of the software, but that now makes no difference. Attached is a png file that shows what is set and the single Color PF that has these setting with only the last color showing. |
Attachment Deleted. |
| [2018-10-06 23:36:42] |
We will check on this.
| [2018-10-08 14:26:22] |
| Handle - Posts: 36 |
Hello I am having the same issue. Even went in and reconfigured a butting and still will only draw all lines same color regardless of setting changes |
| [2018-10-08 19:29:16] |
This will be resolved in the next release.
