Date/Time: Fri, 06 Nov 2026 08:08:57 +0000
Trade copier
View Count: 4767
[2018-09-19 20:01:27]
User935626 - Posts: 8
Hi there,
I am looking for trade copier to trade multiple future accounts using the one main DOM or chart, is that possible, if yes which brokers support this? I have read few threads on your support Board, still not clear if this is possible. Appreciate your help.
[2018-09-19 21:13:47]
This is not currently supported directly within Sierra Chart but it is planned. If you will be relying on the external Trading service to do this, then check with them to see which ones can do this. They are all listed here:
Supported Data and Trading Services
Date Time Of Last Edit: 2018-09-19 21:14:14
[2021-03-23 08:51:47]
User888583 - Posts: 20
You might be interested in AimFX Trade Copy bridge for Sierra Chart/MT4/MT5 - https://aimfx.io/sierra-chart-trade-copy-tool/
It is common practice to copy between multiple MT4/MT5 accounts. Though, it was not supported for futures accounts.
With this bridge, you could attach a study to one of your charts which enable copying to MT4/MT5.
Personally I use Sierra to do analysis and take a trades on Sim account and they are copied instantly to MT4/MT5.
Interesting thing would be to use Sierra Chart to trade stocks - but my stock broker do not allows to use Sierra. Instead I am trading Sierra NYSE/NASDAQ stocks and copying their execution to MT4 brokers with stocks cfds.
Copying between one Sierra Chart instance and another Sierra Chart instance is not yet supported, but it will be in a future.
Long run, I was thinking about exposing DTC Service so you can natively connect to AimFX platform with Sierra, but that would require several months of work.
Cheers,
Lukasz
[2021-06-22 01:32:54]
cfuture - Posts: 86
Hi Lukasz, I am highly interested in how you have managed to have copies from sc sent to mt4/5? I would also like to know which data provider you are using when using sc in sim mode? It would be great if you could help me out. thx!
[2021-06-22 07:17:53]
Feel free registering on the website - https://AimFX.io/
There is no separate data provider. You trade using your existing datafeed. Trades can be taken on real or sim account.
Those trades are taken to AimFX copier engine and distribute to the followers.
You can configure MT4/MT5 as receivers. In future others...
Give a shot and register. Currently everything is for free, but as of July 1st, this tool will be available after subscription. More you can read on the website.
Lukasz
[2021-06-22 16:29:25]
cfuture - Posts: 86
Hi Lukasz, I checked out the website and certainly it is of interest. I am wondering though about the datafeed. I guess you are getting your data from SC if you are only trading forex, but the prices are from FXCM.
Date Time Of Last Edit: 2021-06-23 21:53:21
[2021-10-11 23:55:07]
HumblyTrading - Posts: 226
Hello Lukasz,
Thank you for these posts and for developing the tool you have been working on with AimFX.
I plan to join shortly as a workaround to managing several accounts through AMP and some others.
Just a question on rough timing. Do you think SierraChart Master to SierraChart slave will be supported in 2021?
Thanks!
Mike T
[2021-10-12 05:07:55]
Hi miket,
Currently this feature is under development. I plan to release it within next month or so.
Lukasz
[2021-10-12 06:05:04]
I will sign up within the next week or so. Thanks!
[2021-10-12 06:07:02]
yes, thats the best way. I am informing all users about the changes. When I finish testing, I will give everyone know about it.
Lukasz
