Date/Time: Fri, 13 Nov 2026 18:36:08 +0000
Orders And Positions Window - executed orders disappear
View Count: 906
| [2018-09-04 09:58:41] |
| SC - Posts: 9 |
Since upgrading to version 1795, any Sim orders executed appear in Orders and Positions window for 2 minutes only then disappear. The executions can still be found in Trade Activity window. They used to stay in Orders and Positions until I logged off and I prefer this. Is there a glitch in 1795? I rolled back to version 1785 and this does not happen in 1785 Date Time Of Last Edit: 2018-09-04 10:13:05
| [2018-09-04 10:23:04] |
No, this is now done for maintaining maximum performance in the order list and assuring sub millisecond order handling. You do need to refer to the Trade Activity Log for the history.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-04 10:23:39
| [2018-09-05 08:27:22] |
We will increase the amount of time that the orders are persistent. Right now it is two minutes but we will increase it to 15 minutes. At some point we do have to make this adjustable.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-05 08:27:40
