Date/Time: Fri, 13 Nov 2026 18:36:11 +0000
Zig Zag Extension Lines
View Count: 1215
| [2018-09-03 07:42:34] |
| User740496 - Posts: 32 |
Updated to 1795 - extension lines (SG8) in Zig Zag indicator not working correctly. If using a Line with Dash and width "1" - it appears as solid line not a dashed line. If I change width to "2" then it switches to a dashed line. Please can you check dash line at width "1" which has been my setting for ages.
| [2018-09-03 19:39:47] |
We will look into this.
