Date/Time: Fri, 13 Nov 2026 18:46:01 +0000
TPO Chart right side
View Count: 1662
| [2018-08-31 18:00:30] |
| User883370 - Posts: 6 |
Hello, I have seen this white Line on the right side of the TPO-Chart. How to set this line. Is this a Volume Profile? How to set in TPO, please help. File attached ... |
| [2018-08-31 18:09:07] |
| User750920 - Posts: 297 |
I am only a week into testing Sierra but that looks to be a Volume by Price (VbP) study. Go to Analysis>Studies (F6) and look for the VbP study to edit it.
| [2018-08-31 18:26:01] |
yes, I think so too. but I don't find any possibility to adjust this. TPO and Volume by Price together is no problem. but if TPO activ the volume profile on the right side is gone |
| [2018-08-31 20:56:52] |
| John - SC Support - Posts: 48527 |
It is possible to have a Volume by Price study on the chart that is not associated with the TPO profiles. To do this add an additional Volume by Price study to the chart and then use the settings found here to set it to the right side as seen in the original image: Volume By Price Study: 30 Minute Volume Profile at End of TPO Profile Chart In order to get the outline view of the VbP, set the Volume Bars Draw Method to Hologram. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
