Date/Time: Fri, 13 Nov 2026 18:46:09 +0000
DTC protocol failure
View Count: 1594
| [2018-08-30 05:44:05] |
| User525733 - Posts: 126 |
Hi, I followed the procedure outlined in the link below in order to view market data and trade from a second windows machine on my local network. Using DTC Server for Data and Trading in Another Sierra Chart Instance "Using DTC Server for Data and Trading in Another Sierra Chart Instance" --------------------------------------------------------- the error log from the SERVER machine was as follows: Socket (9) | Socket gracefully closed by remote side. | 2018-08-30 00:38:47 Socket (9) | Closed. | 2018-08-30 00:38:47 Opened cached Intraday file: C:\SierraChart\Data\F.US.EPU18.scid | 2018-08-30 00:38:59 DTC Protocol server | Incoming connection from 192.168.0.103. | 2018-08-30 00:39:31 DTC Protocol server | Rejecting connection from 192.168.0.103. | 2018-08-30 00:39:31 * DTC Protocol server | Incoming connection from 192.168.0.103. | 2018-08-30 00:39:34 DTC Protocol server | Rejecting connection from 192.168.0.103. | 2018-08-30 00:39:34 * DTC Protocol server | Incoming connection from 192.168.0.103. | 2018-08-30 00:39:37 DTC Protocol server | Rejecting connection from 192.168.0.103. | 2018-08-30 00:39:37 * DTC Protocol server | Incoming connection from 192.168.0.103. | 2018-08-30 00:39:40 DTC Protocol server | Rejecting connection from 192.168.0.103. | 2018-08-30 00:39:40 * DTC Protocol server | Incoming connection from 192.168.0.103. | 2018-08-30 00:39:44 DTC Protocol server | Rejecting connection from 192.168.0.103. | 2018-08-30 00:39:44 * ---------------------------------------- error message from the HOST machine was as follows: DTC - Sub Instance | Connecting to the server 192.168.0.101. Port 11099 | 2018-08-30 05:39:35 DTC Client socket (9) | Creating socket. | 2018-08-30 05:39:35 DTC Client socket (9) | Connecting to IP: 192.168.0.101. | 2018-08-30 05:39:35 DTC - Sub Instance | Connected to server. | 2018-08-30 05:39:35 DTC - Sub Instance | Starting socket receive thread. | 2018-08-30 05:39:35 DTC - Sub Instance | Sending encoding request to server: Binary VLS | 2018-08-30 05:39:35 DTC Client socket (9) | Socket gracefully closed by remote side. | 2018-08-30 05:39:35 DTC Client socket (9) | Received socket Close event. | 2018-08-30 05:39:35 DTC Client socket (9) | Initiating close of socket by core. | 2018-08-30 05:39:35 DTC Client socket (9) | Write in progress. Shutdown being delayed. | 2018-08-30 05:39:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-30 05:39:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-30 05:39:35 DTC Client socket (9) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-30 05:39:35 * DTC Client socket (9) | Write has completed. Shutdown being performed. | 2018-08-30 05:39:35 DTC Client socket (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-30 05:39:35 DTC Client socket (9) | Closed. | 2018-08-30 05:39:35 DTC - Sub Instance | Disconnected. | 2018-08-30 05:39:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-30 05:39:35 I am using CQG data with AMP. I tried to disable the firewall on the server machine to no effect.....please advise thanks |
| [2018-08-30 07:25:45] |
How is Global Settings >> Data/Trade Service Settings >> SC Server Settings >> Allowed Incoming IPs set? Change it to a less restrictive setting.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-30 07:25:55
