Date/Time: Fri, 13 Nov 2026 18:46:18 +0000
problem with vertical scale
View Count: 1401
[2018-08-29 17:18:55]
User828417 - Posts: 32
I have one chart that won't allow me to change the vertical scale with CTRL-click in vertical. It's the only chart doing this and I opened it the same way as my other charts (via QuoteBoard).
Any idea how to fix?
[2018-08-29 17:34:41]
Refer to the instructions here:
Chart Scale and Scale Adjusting: Interactive Scaling
You may have Logarithmic scaling enabled.
[2018-08-29 19:25:36]
I checked scale, and it was set to linear.
Any other ideas?
[2018-08-29 19:57:09]
Make sure the scale is not locked:
Chart Scale and Scale Adjusting: Locking the Scale
Also select Chart >> Reset Scales.
