Date/Time: Fri, 13 Nov 2026 18:58:19 +0000
64 BIT
View Count: 1066
[2018-08-22 14:50:44]
User28317 - Posts: 155
WHEN I LOOK AT HOW SIERRA CHARTS IS RUNNING ON MY COMPUTER I SEE THE 32 BIT VERSION RUNNING, NOT THE 64 BIT. MY COMPUTER IS A I-7 PROCESSOR, SO I WAS WONDERING WHY I'M RUNNING ON THE 32 BIT VERSION?
I HAVE VERSION 1705
Date Time Of Last Edit: 2018-08-22 14:54:01
[2018-08-22 15:21:01]
User75002 - Posts: 117
You must use the SierraChart_64.exe program in the root of your SierraChart folder. Create a shortcut to it on your desktop or just modify your existing shortcut to point to the SierraChart_64 executable.
[2018-08-22 17:10:53]
Start Sierra Chart using the shortcut on your desktop that has "_64" at the end.
Date Time Of Last Edit: 2018-08-22 17:11:05
