Date/Time: Fri, 13 Nov 2026 19:10:11 +0000
CQG Connection Error
View Count: 1063
| [2018-08-10 02:55:23] |
| oldporkchops - Posts: 1 |
"Trader is not enabled to use FIX connection. Contact your FCM." This error message isn't listed in the Common Error Messages under the CQG guide. Could you please help? Thanks. |
| [2018-08-10 04:32:36] |
Contact your broker and have them enable your CQG account to use the FIX connection with CQG. It probably is not listed because this particular message has changed on the CQG side possibly.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-10 05:27:27
