Date/Time: Thu, 01 Oct 2026 23:23:07 +0000
I can't find the way to get data from TPO Picks and Valleys
View Count: 911
| [2018-06-28 21:16:49] |
| User517260 - Posts: 97 |
Dera Sir, I can't find the way to get data from TPO Picks and Valleys on Renko bars. At first, TPO doesn't allow use renko bars as I see, at second - I've got error after attempt to get data from SG28 and SG29 of TPO indicator. Could you help me? Thanks, Alex.
| [2018-06-29 04:59:20] |
This data is only accessible through ACSIL with this function: ACSIL Interface Members - Functions: sc.GetStudyPeakValleyLine() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-06-29 07:38:01] |
Thanks!
