Date/Time: Mon, 05 Oct 2026 13:07:12 +0000
[Programming Help] - logging more than one time
View Count: 797
| [2018-06-27 11:12:07] |
| User30743 - Posts: 399 |
hello i have a question on how to solve logging into message log. i have written a simple aos and what i need is that when an entry is made, a message into log should come with some parameters of the entry that i have defined. for 99% of cases it works fine but SOMETIMES it happens that the message into log is sent more than one time for the same entry (and with different parameters) i have no idea why it happens because in the code i have written it should log ONLY ONCE for each entry. can you please help me to solve this issue because i need to have for each entry only ONE line in the message log so that the number of lines in message log with be exactly the same as the number of lines in the tradelists.txt Date Time Of Last Edit: 2018-06-27 11:12:36
