Date/Time: Mon, 23 Nov 2026 15:57:27 +0000
Rithmic and SC data
View Count: 4122
[2018-06-19 22:07:03]
ertrader - Posts: 701
If using Rithmic, is SC real-time and historical data needed for reliability and Market depth? I'm moving from IB to Rithmic and with IB I do need the SC data feed.
[2018-06-20 03:14:15]
No, but we really do not favor Rithmic. We state this here:
Rithmic Trading Platform Service
The connection Sierra Chart uses to Rithmic is regarded by us as a "hack".
Date Time Of Last Edit: 2018-06-20 03:14:32
[2018-06-20 03:32:43]
Thank you..VERY helpful. With IB and Rithmic as less than ideal, what would be a better choice for reliability, market depth and Linux experience. This is a significant move for me so your candor and best guidance is very much appreciated. Linux has proven to be quite good despite minor issues.
Date Time Of Last Edit: 2018-06-20 03:48:57
[2018-06-20 03:46:13]
If you are using Linux, then do not use Rithmic. That is out of the question.
If you want to know the truth, there is nothing that we regard really as very good or the best.
If you are a high-volume trader perhaps you could look at using the CTS low cost connection model:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel
[2018-06-20 20:02:23]
For the new CTS connection option, does any CTS broker participate? deepdiscounttrading.com is who I'm considering although I'm open to others. This is for Futures trading
Date Time Of Last Edit: 2018-06-20 20:33:29
[2018-06-21 04:59:51]
All CTS brokers can use this new connection model.
[2018-07-20 13:40:56]
Thank you. It's taken awhile to get the accounts set up and completely migrated off IB.
I am now using CTS order routing through ADMIS, data from SC and all is working flawlessly on Linux! This configuration is also nice because it removes one more application needed on my computer.
Jerry at Futurepathtrading is the broker that got everything set up and have been outstanding to work with!
[2018-07-20 16:25:15]
Since you are with CTS you can use this connection to lower the per contract fees:
You can still switch over to the direct CTS FIX connection at any time you want.
Date Time Of Last Edit: 2018-07-20 16:25:27
[2018-07-20 16:41:16]
Yes... that is how I am set up and ADMIS is the FCM. It's working great so far. I made the necessary changes in my SC profile. Please let me know if there is anything else needed. I'll be testing orders over the next few days.
Date Time Of Last Edit: 2018-07-20 16:41:55
[2018-07-20 17:28:49]
It does not appear so from the particular Service you are using.
Did you follow through these particular step-by-step instructions:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#LowCostConnectionModel_Instructions
[2018-07-20 17:37:19]
Yes, I followed them exactly... they were very well done! thank you
[2018-07-20 17:58:37]
Select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to?
[2018-07-20 20:42:17]
CTS T4 Fix (trading). Use Live Server is selected, Fast Trade is selected, Perform Hardware ID Check: True, Unbundle CME Trades: True.
Date Time Of Last Edit: 2018-07-20 20:44:31
[2018-07-20 22:53:09]
Right that is what we thought. In this case, you do not take advantage of the lower CTS fees. You pay the full fees. You need to use "CTS Trading - DTC". Refer to 15 through 17 here:
[2018-07-21 01:05:38]
Thank you... I have made the change.
[2018-07-22 14:24:33]
For the account setup in SC control panel: Add External Service Login Details:
I have set this to CTSOrderRouting.ADMIS.DTC
Is this correct? Should this be my my CTS login username and PW or my ADMIS login username and PW?
[2018-07-22 17:01:30]
Yes this is correct. And it will be the CTS username and password.
[2018-07-22 17:11:23]
Great... got it, thank you!
[2018-07-27 14:45:00]
I am seeing this error.
CTS Trading - DTC order update (Order reject). Info: CTS order update (Rejected). Info: User not allowed to trade. Text: Parent order. Tag: ES2.twconfig. Internal Order ID: 5686. Service Order ID: 15047. Symbol: ES.20180900.CME_Eq | 2018-07-27 10:40:16
Can you please check to see if everything on SC side is correct? If so, I will follow up with ADMIS
[2018-07-27 16:01:55]
Contact your broker about this. This error is from CTS.:
