Date/Time: Mon, 09 Nov 2026 15:04:53 +0000
Cumulative Daily Delta
View Count: 1169
| [2018-05-22 11:35:41] |
| User294443 - Posts: 14 |
Hello Is there anyway you can display the Cumulative Daily Delta as a column in the QuoteBoard? I find it very useful. Thanks. |
| [2018-05-22 19:14:08] |
No definitively not, but you can display study values through the Study Summary window: http://www.sierrachart.com/index.php?page=doc/StudySummaryWindow.php We are not really sure of the calculation you want to do but you will be able to do that with one of the studies or a combination of them. For example have a look at Cumulative Delta Bars: Cumulative Delta Bars - Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-22 19:18:58
