Date/Time: Mon, 29 Apr 2024 00:56:13 +0000
Compile error in latest SC version
View Count: 2346
[2018-06-22 19:25:43] |
ertrader - Posts: 645 |
This appears to be resolved for me in v1767. I've recompiled and appears correct now.
[2018-06-22 20:00:43] |
Yes this has been resolved. It had nothing to do with the 64-bit version. It was simply a case of an uninitialized variable in a data structure. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-25 08:01:43] |
T44 - Posts: 363 |
I can confirm that I'm receiving this error on version 1768 (32 bit) scstructures.h:80:26: fatal error: SCSymbolData.h: No such file or directory |
[2018-06-25 09:42:43] |
How are you performing the build? Is this using Remote Build?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-28 18:33:21
[2018-06-25 21:11:42] |
T44 - Posts: 363 |
Hello Support This is both using remote build and ming/g++ on GNU/Linux (which has complied my studies successfully in the past) |
[2018-06-28 17:21:32] |
We cannot reproduce this problem on either the 64-bit or 32-bit version using 1768 with remote build. Or even the latest prerelease. scstructures.h:80:26: fatal error: SCSymbolData.h: No such file or directory
Are you still having the problem with Remote Build?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-28 17:22:17
[2018-06-28 20:56:10] |
T44 - Posts: 363 |
Hello Support A different error this time -- Starting remote build of Custom Studies Source files: x.cpp. -- 21:54:24 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: herbert.cpp:3:30: fatal error: scstudyfunctions.h: No such file or directory #include "scstudyfunctions.h" ^ compilation terminated. -- End of Build -- 21:54:27 |
[2018-06-28 20:59:09] |
That particular header file is something that does not exist when doing a remote build. You need to take whatever code you need from that header and the associated CPP file, and add it to your own CPP file.
[2018-08-26 12:00:29] |
T44 - Posts: 363 |
Hello Support, I am still having this issue even on a local build: In file included from sierrachart.h:15:0, from MyStudy.cpp:2: scstructures.h:80:26: fatal error: SCSymbolData.h: No such file or directory My includes look like: #include "sierrachart.h" #include "scstudyfunctions.h" command being run is i686-w64-mingw32-g++ -fpermissive -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -w $MyStudy.cpp -o $MyStudy.dll |
[2018-08-26 21:44:56] |
Does this file exist: SCSymbolData.h in the same folder where SierraChart.h exists? Make sure the case of the characters is the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-27 13:13:27] |
T44 - Posts: 363 |
This is a Linux system, therefore case sensitive. your scstructures.h: contains #include "SCSymbolData.h"
However the filename is scsymboldata.h Making a symlink fixed the issue. Thank you. SierraChart/ACS_Source$ ln -s scsymboldata.h SCSymbolData.h
