Date/Time: Mon, 02 Nov 2026 00:12:17 +0000
Inverse fisher trasform
View Count: 1798
| [2013-10-09 15:19:39] |
| crazybears - Posts: 314 |
Hi SC Support seems inverse fisher trasform indicator doesn't work . returns 1# for each time frame thanks |
| [2013-10-09 22:00:01] |
This will be solved in the next release.
