Date/Time: Tue, 10 Nov 2026 18:05:01 +0000
ChartbookExample.cht Issues
View Count: 1628
| [2018-05-06 01:53:16] |
| User223734 - Posts: 120 |
When I download the current version "1738", I suppose have a "ChartbookExample.cht" file. I try to open it as before but the "Log" indicated "ERROR" and can't open it. |
| [2018-05-06 23:12:23] |
We will check on this.
| [2018-05-07 02:53:23] |
This will be solved in the next release.
