Date/Time: Tue, 10 Nov 2026 17:53:08 +0000
Projecting the SierraChart to a bigger monitor.
View Count: 1592
[2018-05-01 19:48:05]
User800328 - Posts: 50
I am projecting the SierraChart to a bigger monitor but it does not fit nicely resolution wise. It is cutoff from edges and show big resolution images.
Can you please tell me if I have to do anything special for it to work.
[2018-05-01 19:52:35]
The cut off problem is a monitor issue.
What do you mean by big resolution images? You can customize various graphics related settings in the Graphics Settings window:
http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html
