Date/Time: Tue, 10 Nov 2026 17:53:12 +0000
[Programming Help] - Offsetting arrows from bar High/Low
View Count: 1197
| [2018-05-01 13:57:49] |
| Eric Uva - Posts: 6 |
On the spreadsheet system for trading and the spreadsheet study, I would like to use "arrow up" and "arrow down" on columns other than K-N. However, when I do so, the arrows appear on the chart at value = 1. This dramatically skews the chart. What setting should I change to have up arrows offset from the bar low and down arrows offset from the bar high? Said differently, I would like the up/down arrows to appear on the chart exactly as they do for columns K-N. thank you, |
| [2018-05-01 17:47:03] |
Your Sierra Chart account is expired. Do you have an active account?
| [2018-05-01 17:59:03] |
| User606491 - Posts: 164 |
yes, this was a temp account. I've reposted under my actual account. Problem has been solved by a community member. |
| [2018-05-01 19:51:30] |
This is explained here: http://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#ControllingTheLocationOfArrowsOrSubgraphValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
