Date/Time: Tue, 10 Nov 2026 17:53:01 +0000
How to change the name that is in the drop down box in the Dom
View Count: 1401
| [2018-05-01 03:13:48] |
| User432504 - Posts: 73 |
SC: How do I change the name that is in the dropdown box in the SC Dom? I have changed the targets and the stops but how do I change the name from, for example simple bracket to CL bracket? The SC software DOM came with a few brackets in the dropdown menu but how do I add a name to the one i just did for the CL? |
| [2018-05-01 19:14:32] |
Here is the relevant documentation for this: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#TradeWindowConfigurations There are several subsections below that section with additional information as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
