Date/Time: Thu, 19 Nov 2026 11:55:06 +0000
Replay Multiple Chartbooks
View Count: 2981
| [2018-04-30 23:51:46] |
| User379468 - Posts: 508 |
Any way possible to support replaying multiple chartbooks simultaneously? This would be incredibly useful to simulate complete regular trading, vs only one chartbook at a time.
| [2018-05-01 00:14:30] |
You can do this but you have to manually start them one at a time.
| [2018-05-01 15:57:11] |
| User948528 - Posts: 108 |
Please consider adding support to synchronize this across all chartbooks, would be excellent, thank you.
| [2021-02-09 06:53:56] |
| User472997 - Posts: 9 |
Please do consider adding a feature that synchronize multiple chartbook for replays. So basically, one replay control panel for multiple chartbooks. Thank you! |
| [2021-03-24 22:49:25] |
| User453167 - Posts: 6 |
./push
| [2022-03-07 20:45:16] |
I support the request that synchronize multiple chartbook for replays. I have been doing manual replay for each chartbook but it can be hard to make it all play in perfect sync. They are always seconds off from each other. Appreciate it! Thank you |
| [2022-05-28 21:39:02] |
| dbtrade - Posts: 24 |
Or even across instances... Seems like one instance is already acting as the master data feed, although I have no idea how you have implemented that. The obvious use case is trying new chartbooks alongside familiar chartbooks. Thank you for what you do. |
| [2022-05-31 14:51:40] |
| John - SC Support - Posts: 48583 |
Running replays across instances is not supported.
| [2024-10-31 14:48:44] |
| Deenius - Posts: 176 |
We really need this functionality. I usually analyze in one chartbook and trade in another. Replaying both at once makes perfect sense to me. Please, implement it. Thank you. |
