Date/Time: Mon, 06 May 2024 00:19:25 +0000
[User Discussion] - A Better Implementation of Interactive Broker's Data Feed
View Count: 11390
[2013-10-20 23:31:38] |
Yes. We are able to deliver a solid solution to this. We have a new data feed available that you can subscribe to starting around the beginning of next month: Notice: New Futures Real-Time Data Feed We will be putting no further time into interactive brokers data feeds. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-02 01:38:22] |
FFTrader - Posts: 180 |
Questions: 1. I am using your current offered connection with Interactive Brokers. I guess it is still usable to trade given its inaccuracy? (not expecting an 100% answer from this question) 2. In the Data/Trade Service Settings screen - after selecting Interactive Brokers, the setting "Simulate Trades to Match Daily Volume" is constantly set to "True" and cannot be changed to "False". Such a "setting" is part of the solution depicted above in this thread and I guess I should NOT worry about it? I am speculating "Bad Dog" is in British Columbia and just want to mention that I am also in British Columbia. If so, thank you Bad Dog for putting this accuracy issue on the map! Date Time Of Last Edit: 2014-11-02 01:39:12
