Date/Time: Mon, 21 Sep 2026 10:46:40 +0000
Configuration from old installation not tranferring to new one
View Count: 947
| [2018-04-26 04:46:08] |
| User150371 - Posts: 70 |
I did a complete re-install of SC, and saved a backup of all the files from my previous version. I followed all the instructions on how to transfer files to the new version here : Transferring Sierra Chart Settings and Data From Existing Installation to New Installation But my old configuration -- buttons, global graphics -- is no longer present. Any suggestions ? |
| [2018-04-26 18:19:03] |
Make sure you have restored the Sierra3.CFG file from your backup. Those particular settings are contained in that file. And make sure that file is copied into the Sierra Chart installation folder when Sierra Chart is not running. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
