Date/Time: Mon, 21 Sep 2026 10:47:17 +0000
1736 Not opening 3 instances
View Count: 965
[2018-04-26 02:44:22]
Acro - Posts: 459
I have my global general settings set to run 3 instances.
However, when I start up Sierra it only opens instances 1 and 3 but not 2.
I believe this may have been caused by my migrating instances 1 and 2 from one hard drive to another whereas instance 3 was created on the new hard drive.
Is there any way I can "reset" instance 2 so it does open on startup ?
Thank You
[2018-04-26 15:12:43]
Acro - Posts: 459
I realised that I had not found the instructions clear enough.
What I want can be achieved by typing "2,3" in the Global Settings - General Settings - Instances to Run on Startup box
