Date/Time: Tue, 10 Nov 2026 17:40:50 +0000
Sierra Folder / Size
View Count: 1116
[2018-04-23 16:25:04]
User371906 - Posts: 141
My current SierraCharts folder is larger than 61 gigs and wonder If I can delete non needed folders like perhaps historical data?
Please let me know which folders might I be able to delete to reduce size.
Thank you
[2018-04-23 18:16:33]
You can delete the Intraday chart data files for symbols you are not using. Refer to:
Chart Data and Chart Data Files: Deleting a Chart Data File
You can also delete market depth data files. Refer to:
Chart Data and Chart Data Files: Deleting a Market Depth Data File
Date Time Of Last Edit: 2018-04-23 18:17:19
