Date/Time: Fri, 06 Nov 2026 08:17:17 +0000
Microsoft Visual Studio 2017
View Count: 3122
| [2018-04-12 17:05:53] |
| User366976 - Posts: 3 |
Dear all, will be someone so kind and write some instructions or short manual what type of new project and what setting are needed to make a custom study in Visual Studio 2017? Thank you in advance. |
| [2018-04-12 19:05:07] |
We do not provide support for this other than what we have here which may be out of date: https://www.sierrachart.com/index.php?page=doc/UsingVisualCPlusPlus.php Instead we recommend following the instructions here and use the Remote Build Command: Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-12 19:05:35
| [2021-09-23 16:19:48] |
| User0171 - Posts: 8 |
If you're going to do that, the "short manual instruction" won't affect it at all. I tried that once, and how I expected it was for nothing, and I just lost my time there by doing that one. Hopefully, my work-life changed a lot by getting it on office 2019 key cheap. When I received my key and activated it, I began to work better than usual. Maybe there's any chance that I'm gonna get the windows 11 as well. I need to wait for it to be available for my processor.
Date Time Of Last Edit: 2021-09-26 14:10:53
