Date/Time: Tue, 10 Nov 2026 17:28:55 +0000
64 Bit
View Count: 1668
| [2018-04-12 16:25:52] |
| User41288 - Posts: 13 |
Hi I have upraded to latest new version 1727 after download but its showing 32 Bit. I wanted to try 64 Bit which it was showing for some time but then it went back to 32 Bit. My PC system is 64 Bit one. Would you help Please. Thanks
| [2018-04-12 19:21:50] |
You should see an icon on your desktop for Sierra Chart with _64 in the name. Use that to start Sierra Chart. For more information refer to: Software Download: Difference Between 32 and 64-bit Versions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
