Date/Time: Mon, 16 Nov 2026 16:35:06 +0000
Study Summary sorting problem
View Count: 1542
| [2018-04-10 14:39:47] |
| wwwingman - Posts: 185 |
Hi, I use the study summary that I find highly useful. Thank you ! (don't need the ninja market analyzer anymore !) But, I am unable to sort the charts like I want and believe to be possible according to the documentation. I would like the order of the charts to be the same as it appears in the Windows and Chartbooks feature. But, they appear in the chart number increasing or decreasing order. I tried clicking multiple times on the Chart Header Study Summary for switching modes but it continues to give the same increasing/decreasing chart number mode, not the one I chose in the Windows and Chartbook. FWIW : The Sort Lock option Is not selected. Am I missing something ? I am using version 1727 . -- W. Date Time Of Last Edit: 2018-04-10 19:20:10
| [2018-04-10 19:10:29] |
Looks like there might be a problem with this. We are looking into this.
| [2018-04-11 21:12:06] |
This is resolved in prerelease 1731.
| [2022-01-12 18:31:10] |
| User379468 - Posts: 508 |
V 2342, sub instance, this issue is still occurring. Followed all instructions at : Study Summary Window: Chart Management Related to Study Summary Study Summary chart order does not follow order set in Window > Windows and Chartbooks. Sorting not enabled. |
| [2022-01-18 16:22:31] |
Can you help fix this?
| [2022-01-19 04:48:15] |
| Sierra_Chart Engineering - Posts: 25428 |
That documentation is out of date. Windows and Chartbooks no longer controls the order of charts within the Study Summary.
| [2022-01-20 15:56:19] |
How can one change the order the Study Summary displays on a chartbook already set up with many charts?
| [2022-01-20 16:21:52] |
The order of the charts seem to be the one used by the lower tabs of the charts. Move the tab of a chart, for ex from most left to most right, and you will see it move in the study summary from top to bottom. |
| [2022-01-20 18:07:04] |
Move the tab of a chart, for ex from most left to most right, and you will see it move in the study summary from top to bottom. How can it be done for multiple detached charts in each chartbook? I don't see tabs for each chart. Date Time Of Last Edit: 2022-01-20 18:07:21
| [2022-01-20 19:39:23] |
Re-Attach the chart, it will appear as a tab. Move the tab to get the right position. Detach again...
Date Time Of Last Edit: 2022-01-20 19:39:47
| [2022-01-20 23:14:24] |
Wow, what a strange, tedious, and useful workaround, it worked, thank you! I guess SC can update the documentation with this tip if it is the only way now. P.S., will DM you. |
