Date/Time: Tue, 10 Nov 2026 16:56:50 +0000
how get 2 min graph button on the customize control bar 1 ?
View Count: 1905
[2018-03-20 13:56:03]
User991843 - Posts: 3
Hallo,
how can I get 2 min graph button on the customize control bar 1 ?
Standard is 1,5,10,30 min. It is no problem. I need 2 min.
Is it possible ?
If yes, please how ?
Thank you.
Aneta.
[2018-03-20 14:20:53]
Xfanman1 - Posts: 320
Yes, it's possible and easy to do. Follow the directions via this link -->
Control Bar: Custom Buttons for Intraday Chart Bar Period
Attached is an example of my Time and Renko buttons I use.
Scott
imageButtons.PNG / V - Attached On 2018-03-20 14:20:39 UTC - Size: 31.8 KB - 719 views
[2018-03-20 17:35:36]
Here are instructions for this:
